I need to know if this can work I have 2003 Silverado with on3 perf. turbo kit truck runs ok but i dont want to blow it right away can anyone help. My set up is;
4.8 on3 turbo circle d 3000 stall 223 cam stock injectors
You are going to need bigger injectors and fuel pump to run a turbo.
No way stock injectors can pump enough fuel.
yea i order ls7 injectors thinking they where just bolt on and i was wrong lq aftermarket injectors are so expensive but thanks for the input anyways, don't hurt to ask but is there is anything else that i have to change for only 6 lb like timing or deleting the mass air flow
