hi guys ,
i swap a ls3 into a brookwood 69 whit the gm perf harness and p67 ecu , the problem i got right now is i do not have rev limiter, so i can't do a crank shaft syncro and i got that engine code .(do we have a way to do it whit out the rev limiter )
the car start and run one time in 10 try due to the cam and crank syncro.
i try to adjust the rev limiter by a lot of way and i still not get one maybe is something in the tune that cause me this problems but i need to figure out what it is before i put back the 305 lol
the engine came from a 2010 camaro , have headers , gt9 cam , ported heads , procharger . i make great power when he run .
if you need my tune file let me know
thanks for the help
