Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 73
Thread: LT1 24X 411 PCM conversion - all of us please step inside
    Nov 2013
    208
    Haha, sorry about that. I ended up on vacation right after I installed the new knock sensor. So no tuning with it yet. Hopefully this week I'll get a few miles in....
    1996 Camaro SS M6 - 24X conversion - stock bottom end - heads - shorty headers - 58mm TB
    Ultradyne 230/238 .565/.565 112+4 - 30 LB red top SVO injectors - LOTS of suspension...
    2002 GMC 2500 HD Duramax M6 - Just starting the tune on a stock motor now that I have a good clutch on order...
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    The reason I asked is because I have been remotely tuning a 1994 Camaro with a 383 stroker LT1/24x reluctor conversion with the 30# skinnys. Tuned both the MAF and lower VE (4000 and down, trended the upper values) in open loop and with a widband. Got it pretty good (428/428) until I went to put it in closed loop.....Fuel trims in idle went from 0 to +20-25????? and wideband went to .85! Give it some pedal and they come down, seems to be only in idle. Looked high and low for a vacum/exhaust leak with no luck. O2's seem to be moving but interstingly, when you first start it up after resetting the trims, the wideband goes to 1.0, the narrowbands are pegged at 50 mv and the trims (and NB) rise from 0 to the +25's and the wideband concurrently heads siuth to .85 or so.....
    Any idea's. Trying to get the info on the O2's (as well as the inop knock sensors) from the owner. It is an EFI connection conversion kit/harness. Unfortunately I was tuning using EFI Lve so I dont have a log or the tune....sorry, broke the number one rule of this Forum :-)
    Any insight
    Thanks,
    Ed M
    PS its running a 2002 Camaro automatic os/pcm
    [email protected]
    Nov 2013
    208
    Hey Ed,
    No idea what's going on there. My tune doesn't do that in CL.
    How big is the cam?
    Where do you have the inj timing?
    Thanks,
    Jason
    Nov 2013
    208
    Hey Ed,
    Did you figure this one out?
    Thanks,
    Jason
    Jan 2006
    Collinsville IL
    697
    Real quick question.
    What MAP sensors are the FI guys using on the LT1 motors? Currently has a 2BAR looking for a 3BAR sensor.
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
  6. #26
    Aug 2009
    Calibrating
    3,378
    Shane with the 2.25 beta you can enter in negative numbers so you can use the zr1 map
  7. #27
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by JasonS5555 View Post
    Hey Ed,
    Thanks,
    Jason
    No Jason, unfortunately the customer wanted the car back so I tuned it in open loop with no issues. If he ever brings it back...he loves it :-) maybe I can crack it open again. Gut says the O2's just arent getting enough good exhaust in idle and are falsely reporting. Once you give it a little throttle, they seem to fall in line ?????
    Thanks,
    Ed M
    [email protected]
  8. #28
    Jan 2006
    Collinsville IL
    697
    Hmmmm. i would like to stick to the old style that comes in the LT1 cars.
    [email protected]
  9. #29
    Jan 2010
    5
    Quote Originally Posted by mowton View Post
    Thanks,
    Ed M
    I went throught the same tuning my car. I Followed the same procedure as you, when i put the car in closed loop same thing happened.
    My NBs were waay off from my wideband. I too had the same ordeal at idle and light cruise. Car ran awesome on OL. Put in CL it would lean out and buck and stumble under light throttle.
    http://www.hptuners.com/forum/showth...2-switchpoints Post number 8
    I played with 5 liter eaters (huge props) config.
    I believe I need to play with the Airflow vs mode table to get my 02s to switch faster. But its very close to my desired afr at cruise.
  10. #30
    Sep 2008
    1,668
    Any insight
    Thanks,
    Ed M
    You've got the O2 bank assignments corrected for the difference in firing order right?
    2023 Durango Hellcat
  11. #31
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by MikeOD View Post
    Yes Mike...
    Maybe I answered too quick...O2 bank assignments, i was thinking the injectors.....which ones are they?
    Ed M
    [email protected]
  12. #32
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by 04blackgmc View Post
    Use the standard old brick style MAP sensor. Should be a plug in swap on a LT1 application...
    Located in Central Kentucky
    ShorTuning
  13. #33
    Dec 2008
    on the Dyno
    1,825
    Ed was the EVAP hooked up still? Generally after a lot of open loop run time fuel vapor builds up in the tank and upon returning the setup to closed loop enabling EVAP it shows a rich condition until the excessive fuel vapor is pulled out. If EVAP isn't functioning then it could be an o2 sensor issue.
    ShorTuning
  14. #34
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by LSxpwrdZ View Post
    Interesting Jim...I will check with Dennis in the morning. We didn't build the setup, it was brought to us because the last guy couldn't get it to run right....you know that drill :-)
    Ed M
    [email protected]
  15. #35
    Sep 2008
    1,668
    Yes Mike...
    Ed M
    Sorry, yes, it's assigning injectors to O2's...your injector bank select table should be set to 01101001 on an older LT1. On an LS1 it would be 01011010.
  16. #36
    Mar 2007
    Florida
    3,772
    Then yes, that was set corectly...
    Ed M
    [email protected]
  17. #37
    Nov 2011
    31
    I just finished up my conversion and I'm dealing with some big fuel trim splits. Hopefully you guys can clarify something for me. I'm wondering if my coils and injectors are wired right for the different firing order.
    Here is how I have it:
    Inj 2-blu3
    Inj3 blu4
    Inj 4 blu43
    Inj 7 blu44
    Coil2 red69
    Coil3 red67
    Coil4 red27
    Coil7 red29
    Does anybody know if my instructions were pre swapped or do I need to swap these still?
  18. #38
    Nov 2011
    31
    Were you guys able to change the vin in the pcm to match the vehicle? I took mine in for emissions testing yesterday and failed because the vins did t match
  19. #39
    Aug 2015
    defuniak springs florida
    24
    So has anyone figured out the KR and how to get to read correctly.
    I'm showing no KR now and by what ive read I need to get a van sensor and ditch he LT1 sensor. it would be nice to be able to dial timing in with no KR issues
  20. #40
    Anyone have anything else to add? Anymore tips or tricks for tuning the 24x conversion. I read a lot of people are doing the conversion but not finding out who has been doing the tuning. How significant of a change in the injector timing tables and also you have to tune the transient fueling tables because the LS1 and LT1 intakes and injector angles are different. Ive been chasing my tail with that one.
