Results 1 to 5 of 5
Thread: EOIT tuning help
    EOIT tuning help
    Im trying to get rid of some of the gas smell and help out some low end tq and was told about delaying EOIT to keep the raw fuel from going out of the open exhaust valve. I have this spreadsheet but am not sure if i have it right and am not sure what values i take from the spreadsheet to use in my tune.
    Here is my cam card and i will attach a copy of my tune and the spreadsheet
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    With that cam and low overlap, you should not need to change your EOIT. I don't usually do that until you get into cams with much more overlap.
    You may want to fine tune your VE/MAF tables. Your VE table look a smidget rich in your idle areas and could be smoothened. Your MAF table needs some work as well and smoothened.
    Bottom line, some of the raw fuel you are smelling probably will be cleaned up once you fine tune you VE and MAF tables.
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
    Nov 2009
    All Around
    3,149
    go for a 17:1 AFR at idle, it will chop nice and have your fuel smell much less. you can adjust your openloop tables to target leaner fueling
    yea i know the maf and ve need to be smoothed a little but it was tuned with a wideband and sweeps 14.3 to 15.0 and is pretty stead at 12.8 at wot. i might try to lean the idle out a little bit. i wasnt really worried about he smell i was going to try to pick up a little bit more bottom end by changing it.
    Aug 2009
    Calibrating
    3,373
    I agree with this, I lean most cams out at idle. If the customer wants to keep the 02 sensors I do an OL idle, or if no 02's just use the OFLA table and put fuel where I want it.
    However any cam size I adjust EOIT, larger the cam the more radical I go.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
