I'm working on installing a supercharger kit on a 2004 F150 that was removed from a 2005 F150 5.4L. The kit came with the ECU from the truck it was removed from. Before I began installing the kit, I read both the stock tune on the pickup being installed, and the tune from the computer sent with the supercharger. The problem is, the tune on the computer sent with the supercharger.....looks stock.
I'm relatively new to tuning Ford's with HPT, but I'm assuming the injector sizing table should reflect what size injectors you are running....right? All values look stock, need an experienced eye to double check my assumption.
This kit has the 42lb/hr Blue Giant injectors:
And I'm assuming in the tune that injector size SHOULD be reflected here if this is truly the tune ran with this supercharger?
I have attached both tunes, they are labeled Stock Read and Supercharger Computer read.
Thanks for any help given!
