Results 1 to 5 of 5
Thread: Maf only , STFT in open loop ?
    Jul 2014
    218
    A friend of mine just picked up a new TA, built 4l60e, cam and related bolt ons.
    I set up the lockup for him and made some shift adjustments, next I' right now , next ill be doing a full re-tune once he gets a few things done.
    As I look through the tune, few things are different then what I have done in the past.
    1st - I see the car is set to run all maf 200 rpm and up, I plan on putting it back to a mix of VE and MAF. Unless someone wants to direct me otherwise.
    2nd - STFT in open loop is enabled, i' ve never seen this done before, is it because of the tune being maf only? Anyone want to school me ?
    Jul 2014
    218
    Bump , any one has a guess on why someone would want Stft enabled during open loop ?
    Sep 2008
    1,668
    It's enabled from GM on some calibrations.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    Jul 2014
    218
    In that case should I leave it enabled ?
    Sep 2008
    1,668
    You can disable it if you want to...I don't see a negative to disabling it.
