Results 1 to 18 of 18
Thread: INJ Duty droping to 0 on shifts.
    Jun 2010
    559
    Every shift in WOT the injector duty cycle drops to 0, anyone seen this or have fix?
    Mar 2011
    21
    i have the same isse
    Surprised to see that the truck appears to be in closed loop the entire time its at WOT! (based solely on active STFT's and fluctuating o2 mv)
    Jun 2010
    559
    That its right ^^^
    Will have to check if its going in PE, I was focusing on the injector shutting down and did not pay attention to that.
    Nov 2009
    All Around
    3,149
    make a status bit for WOT and PE,
    for trucks usually have to lower the PE throttle mapping to enter PE i think stock its set to 87, bring down to like 50
    if you are going to max out the Peak engine torque and still use torque for PE enable it will never go into PE since you will never reach that torque level
    Mar 2014
    McAllen,TX
    160
    x2 if you max out peak you will never go into power enrichment,,,, your having issues when it shifts you havent got rid of the delay where timing drops?
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Jun 2010
    559
    ^^^Timing don't drop no more, just the injector duty cycle drops on shifts.
    I was not going to max out the the max torque peak but i did just see if the inj duty cycle will go away.
    Mar 2014
    McAllen,TX
    160
    are you going into power enrichment ? how are the o2 sensors when you shift ??
    Jun 2010
    559
    Quote Originally Posted by jarrah View Post
    You ralking about this table?
    If i max out peak engine torue should i disable the enable power enrichment?
    Jun 2010
    559
    Quote Originally Posted by Joshtuning View Post
    The only scan i have on shifts the (mV) of the o2 they go to 0 or 4 (mv)
    Mar 2014
    McAllen,TX
    160
    just took a look at your tune and log you have your peak maxed out and you are not going into pe which means your not really making any power
    Jun 2010
    559
    inserting the air fuel ratio commanded hi res in the table display will let me know if i enter in power enrichment?
    Aug 2009
    Calibrating
    3,377
    02LS1 you need to becareful, your playing with fire
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2014
    McAllen,TX
    160
    look at your O2 sensors when regular driving o2 sensors should be bouncing once you floor it o2 sensors should go up without bouncing and should go back to bouncing when you let go actually it goes to O cuz its a 2014
    Jun 2010
    559
    Made some changes on the file, Now the ruck goes on PE and feels way better.
    I change back to stock the maximum peak and got PE at WOT.
    What makes it not get PE when maxing the maximum peak torque?
    Aug 2009
    Calibrating
    3,377
    There is A LOT that needs to be fixed in that tune.
    14 Gen 5 Viper
    Jun 2010
    559
    What else I need to fix?
    I'm learning and will like to know.
    This truck it's just a stock with a muffler.
    I'm not asking for a tune for this truck that's why I bought hptuners to learn, but will like to know what you see wrong here so I can fix it and have something right.
