Results 1 to 18 of 18
Thread: LS2 supercharger install, need some help
    We are going to install Vortech supercharger kit to Corvett C6 LS2 engine 07". Please advise if there is any tuning tip to make a tune of Fuel maps for it and if we need to install 2bar Map sensor and if need to buy extra license for use 2 bar Map sensor enhencement option? or we will be able to tune Fuel with stock Maf and Map sensors?
    On an LS2 if its stock with low boost you will be close to maxing out the MAF sensor. 10 pounds on the top end, or cam headers and it will be maxed out around 5K. You will need to do one of two things for proper fueling. Convert to a 2 Bar custom operating system and run a 2 Bar Map sensor or convert to an LS3/LS7 style MAF sensor and continue as is.
    Bad383TA
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    or scale the tune......
    Ed M
    [email protected]
    We plan to put 5+ psi of boost and LS9 camshaft probably with stock intake manifold. LS9 injectors as well. Will we max out stock MAF with this setup?
    Quote Originally Posted by mowton View Post
    is there any tips how can we do that?
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Stez View Post
    Dave Steck did a great writeup. Go to the injector dynamics site and you can find a link to it.
    Ed M
    [email protected]
    Jun 2011
    Montreal, Canada
    758
    The 2 bar upgrade is now free. There is no reason not to use it.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by realcanuk View Post
    That is absolutely true....either way will do it but free now makes it very appealing.
    [email protected]
    wow really? very cool, i didnt know, please advise, if this is right one or may be need some better one ? other manufacture
    http://www.ebay.com/itm/2-BAR-MAP-SE...efd533&vxp=mtr
    Aug 2009
    Naples, FL
    339
    Get a gm ZR1 map sensor. Do a search here and you will find a part number. Then hit gmpartsdirect.com to order it. I wouldn't trust ebay for a critical sensor like that.
    Zr1map won't work properly on e40 based pcm. We have to use the cobalt one.
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by GXPLS4 View Post
    Reason is -- E40 Map sensor scalar hardcoded at 255 kPa max (ZR1 = 312.5) and offset wont go negative (ZR1 = -11.25)
    Ed M
    [email protected]
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    This is a 07. It has the E38 ECM.
    Jun 2011
    Montreal, Canada
    758
    Wow, just started a thread on this same issue. 07 with and E38. Does a ZR1 sensor fit. I read it doesn't fit the manifold ?
    Alky Control Meth,
    ARH 1 7/8 headers,
    Mar 2007
    Florida
    3,773
    A 3/8 drill bit (IIRC) and you are there.......
    Ed M
    [email protected]
    so in the end, should we better use ZR1 map sensor or search Cobalt one?
    Depends on the ecu
    Jul 2012
    Italy
    219
    What would you use for the e40?
    What is the part number you're referring for the cobalt...
