I'm having an issue where the vehicle stumbles and doesn't want to start right away after cooling off for a little bit.
Cold starts in the morning are fine, and if I shut the car off and turn it back on right away it fires right up. However, if I leave the car off for a hour and come back to it the engine takes twice the number of cranks to fire up.
So far I've messed with the startup airflow a little and the startup enrichment, also did a CASE relearn. Nothing seemed to help, maybe I need to make more drastic changes.
Here's the vehicle specs:
-LS3 built by me, all internals balanced and machined at a a local reputable machine shop
(the shop R&R'ed the crankshaft so maybe the reluctor wheel was not pressed back on correctly?? I'll call and ask if they removed it)
-LS6 camshaft
-Cold air intake
-2.5" exhaust all the way from the headers back (stock headers modified to have 2.5" outlets)
-Chromoly Pushrods
-LS9 Springs
-LS7 Lifters
Haven't checked any hard parts yet.
Does anyone have any ideas on why this might be happening??
Attached a log, the config file, and the current tune on the ECU.
Thanks everyone.
Attachment 47658
Attachment 47659
Attachment 47660
