Alright I'm trying to help a friend straighten out his CTS. I am still learning HP tuners as I go and I have never messed with tuning on a cammed car so bear with me on this.
The car is a 05 LS6 with a T56, He bought it with a cam already installed but shortly after buying the car a lifter failed and it trashed the cam. He ended up pulling out the motor and having the entire thing gone through. It had all new bearings, rings, and gaskets installed along with a Texas Speed MS3 cam (237/242 .603"/.609" 112 LSA). The rest of the motor is stock except long tube catless headers and a K&N intake.
The problem is at idle only when the car is warm, as soon as you start it the RPMS will drop to 250ish and 9/10 times die. If you start it and feather the throttle for 15-45 seconds the car will then idle at 850 with no surging. Its only on startup once warm. On cold start after sitting overnight the car starts just like it should.
The other problem is at idle only it is throwing lean codes and the fuel trims rocket to 25% on both banks which results in it dumping insane amounts of fuel. Once you start moving the trims are almost spot on usually 0 to -1 with the occasional 1 or 2 here and there. even rolling with it in neutral and the RPMS at 850 like it would be idling it is fine, so much so that the trims rolling with it in neutral were 0 every time I checked, As soon as you come to a stop and the speedo reads 0 the trims go straight to 25% again and you can physically hear the engine change tones from all the fuel.
I attached the tune file that is on the car right now, I have not touched it in any way so its exactly as it was when he got it back from the mail order tuner. I have never tuned idle so I don't know where to start, I don't know if the entire idle needs retuned or if something may have been fat fingered and it ends up being a simple fix.
Thanks in advance for any help you can give.
