I've been working on this tune for quite some time now trying to get the ETC throttle opening to come on sooner rather than not fully open until after 4500 rpm... Every time I mess with the ETC max throttle angle table and set it to fully open and take it out and drive it I keep getting the wrench on the dash. Through many hours/days of research I believe this is the IPC causing it but I can't seem to find out how to disable it. It's not like on the older mustangs where you can just set the IPC ROM Switch and IPC ROM Enable both to disable. I've tried setting the IPC Minimum and IPC Maximum tables to the lowest and highest amounts with no luck. Is there some DTC's that I should be disabling for this as well? Any help is much appreciated as
