This is not a tune issue as much as a Transgo install issue. I am posting this more for reference and the off chance it will help someone else down the road.
20141108PMTransStock.hpt
20141108pm.hpl
LS1SDOLBoost tuning.cfg
20141108.hpl
To explain I installed a TransGo HD2 shift kit. Put it all back together and when I shift from Park to Reverse or Neutral to drive is slams into gear and kills the engine. Unless I do not press on the break pedal and just let if free wheel on jack stands. Then it will shift through gears and seems to be fine. I will be pulling the valve body soon to check the hard parts.
