Results 1 to 3 of 3
Thread: Air Fuel Commanded HI Res reading wrong.
    Advanced Tuner =fast='s Avatar
    Jan 2009
    396
    Why the Commanded HI Res its reading wrong?
    Won't go over 13:00 air fuel ratio.
    The file its at 14.62
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    First off your ECT readings are very high 230-241*. If you just did a cam swap or coolant swap, you may still have some trapped air, if not, you might want to give it some attention.
    Since you are in open loop, your commanded hi res PID is referencing your OLFA table. In that table you are commanding 1.12 to 1.13 in that corresponding area(MAP vs. temp). This is why for tuning purposes especially if using open loop, it is suggested that the area from 140F to 284F be set to 1.0 to be at 14.7/1.0=14.7.
    In your case, it would be 14.62/1.0 = 14.62 which is acceptable.
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
    Jan 2009
    396
    Thanks a lot.
    miss that table
