***EDITED (I was asking too many questions at once lol)
My setup consists of the following:
2007 z06
WCCH stage 2 heads (11.8-12.0:1 CR)
Hell widow cam
Halltech 107R intake
Stock exhaust and fuel system
E10 fuel
I'm retuning my car from scratch and plan to start calibrating the MAF and then moving on to the VE table. My goal is to improve drivability (bucking and hot start issues)and try to get rid of some knock I'm getting at WOT in upper RPMs and during transient conditions.
After I put the car in open loop and adjusting all the fuel tables to ensure I'm not trying to hit a moving target, do I put 1 in for the higher temps of the open loop EQ ratio table or the same thing I put in the PE table (i.e. 1.18)? Everything I've read says 1, except for the Master EFI Tuning book by Dan Maslic. So why the inconsistency?
Also, for tuning the MAF I know I need the put the car in pure MAF mode. I plan on doing this by inputting 2rpm in dynamic airflow high RPM disable and 1rpm in the re-enable box. Is there anything else I need to do for this?
During VE tuning, I know I should disable the MAF. I need confirmation on how to do that. Do I need to do something in the DTC tab and/or unplug the MAF? Or perhaps put high values in the dynamic airflow boxes? I know how to do this on LS1's, but I see it's different for E38's.
The attached image is all I need to do to put the car in open loop, right?
Any help would be greatly appreciated.
