Results 1 to 20 of 21
Thread: ID 2000 cc injector flow rate
    Jun 2010
    33
    Hi guys,
    im using id 2000 injectors in my 2002 comaro and the maximum injectors flow rate i can set is 32 g/sec.
    is there anyway that i can increase it more than that to meet the injectors limit which is 33.30 g/sec?
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by mhjoor View Post
    Hi guys,
    You are very close to the limit whereas you could get away with maxing out up top. I would be more concerned about the maximum airflow limits of the MAF and G/cyl based on your requirement for so much fueling......unless you are running E85 or straight ethanol ;-)
    The serious answer is you will need to scale the tune (search for this process on the forum).
    What is your setup for these injectors.
    Ed M
    PS -- Stop yelling, we can hear you
    [email protected]
    Jun 2010
    33
    I have Camaro 2002 project for twin turbo and lsx engine with id2000 cc
    my problem is the maximum injectors flow rate i can set is 32 g/sec and I want to set more than 32
    my friend have EFI Live when he tune same ecu he can set injector flow rate to any digit min 0 max 511 g/sec
    but I try in hptuner only min 0 max 32 g/sec that in same ecu
    I want to finish my project ASAP to start engine
    Sep 2011
    Portland, OR
    522
    I would assume you will have a boost referenced fuel pressure regulator?
    If so, you can run up to 62 psi base pressure, in which case the injectors will flow just shy of 32 g/sec, or 250 gal/hr.
    Those are huge. How much HP are you trying to make?
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by RonSSnova View Post
    ID site data says 33.+ at 400 kPa (58 Psi) fuel pressure so he is slightly over according to that data. Again, you are going to either have to run in Speed Density and tolerate the 1.36 g/cyl limit (IIRC) or scale the tune to get back some high end spark control...Running MAF will surely require scaling as the limit is only 512 g/sec...
    Ed M
    [email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Lower your fuel pressure.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2010
    33
    The problem that I face that the car does not work well, even if I've reduce fuel pressure from regulator still the problem is that the car is very bad idling , even if i try to keep the throttle open its make like to match backfire in exhaust .
    I will tell you what there is in the car will help you to help me
    LSX 434 CI 9.5 Compression Ratio
    LINGENFELTER GT22 HYD ROLLER camshaft
    Trickflow 245 6 bolt Cylinder Head
    injector dynamics 2000cc
    3-Bar Map Sensor 12592525
    Victor Jr. LS1/LS2 Competition EFI Intake Manifold
    90mm throttle body edelbrock
    rossler transmission 4l80e
    And Twin turbo bullseye s366 batmowheel
    This is all parts i have hoop this will help i will send a file also ...
    Mar 2007
    Florida
    3,772
    wow, this went south fast.....from a simple injector flow rate question to a major level tune.......:-)
    Ed M
    [email protected]
    Advanced Tuner Jabbott's Avatar
    Oct 2006
    Richmond
    223
    You can scale the calibration and you will be fine.
    Jun 2010
    33
    need your help in this file
    Nov 2009
    All Around
    3,149
    take it easy, everything can be solved inshalla.
    now with key on engine off can you scan so we can see whats going on and during that scan start engine in the same log.
    if you have a fuel pressure regulator boost reference. your IFR table needs to be flat.
    also make sure your injector deadtimes and minimum pw is correct.
    looking at the tune briefly seems like the data is not correct
    Sep 2008
    1,668
    The transient min fuel milligrams is still stock...that's not going to let you bring down the pulsewidth at idle. I don't remember how to properly calculate that but that number will need to be much lower with those injectors.
    2023 Durango Hellcat
    Jun 2010
    33
    Quote Originally Posted by SultanHassanMasTuning View Post
    thank you and i will try today after i will give you update
    Jun 2007
    Finland, Europe
    549
    Don't. It's been a week since last post.
    We already know.
    Just kidding.
    Threads with no feedback from the OP (original poster) are rather boring. So often they end like this. But I guess it isn't anything unusual. :-)
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Pekka_Perkeles View Post
    We already know.
    Just kidding.
    ^^^^^^ Agreed
    Ed M
    [email protected]
    Jun 2010
    33
    ok ok ok i fix my problem by helping from (( SultanHassanMasTuning )) really you are professional tuning without you i will return to 1000cc injector
    thank you again
    Sep 2011
    Portland, OR
    522
    Would be nice for the rest of us if the solution here was described.
    Mar 2008
    St. Louis, MO
    4,860
    Use the attached file. I went ahead and set up the injector data properly for you. Use 58psi as your base fuel pressure (I assume you use a boost referenced system).
    Jun 2010
    33
    i try two file and i do scan for that file can you check it
    Nov 2009
    All Around
    3,149
    ^ turbo #1 file make IFR table across all 241.70 thats a wrong slope.
