I`m kind of a newb when it comes to tuning as all I have done before was my 0411 pcm`ed 6.0l el camino and I remember taking forever to get the ve table close enough for me to accept it.
Now I`m trying to tune another 6.0l TR220 cam, longtubes, controlled by a 5.3l 6106 blue/green pcm. I started by copying over a stock 6.0l ve table and tuning from there. But no matter what I do it just seems to make the ve table worse. When I started out I was way rich at idle like 40% according to my log and fairly rich for most of the part throttle cruise areas of the table. I copied the whole table, then did the paste special multiply by %. I went from being 40% rich (by the exhaust smell I don`t doubt it was) to 60% lean. I backed out quickly went back to the stock table and did a paste special multiply by % - half. Again it was lean, but only 35% at idle. I have tried to get the VE adjusted multiple times before on this car and I cannot seem to get it within +/- 10%. Either it massively under or over corrects.
I also noticed that I cannot put any sort of filter string on my histogram, every time I do it does not report any data. My VE - WB AFR error hisogram reports no data, while VE - WB AFR error 1 hit 1 has no filter but reports just fine. I tuned the MAF and the car runs pretty well in open loop MAF, but I really want to be able to re-enable the VE.
