Any tips to decrease HC for emission for camed cars ?
It seems that leaning the car in the idle area will not decrease HC
Thanks in advance
Thanks in advance
Maybe running a higher RPM in park will reduce it. It should burn more fuel and do it cleaner.
Do you mean that HC will be decreased if the mixture is richer ?
More spark advance helps, but it will also increase the NOx emissions.
EOIT helps too.
2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
2023 Durango Hellcat
EFI specialist
email=[email protected]
True, but if he's failing for HC at idle, and lives in a state with a drive cycle, he's probably got too much HC everywhere. NOx emissions will increase with more advance off idle, I've seen it happen on many cars...usually from people going past MBT on an engine that doesn't wind up knocking due to the light load.
Another option is bump up the cooling fan on/off temps to allow the engine to run hotter during the test...and get the cats hot before you go test, take it for along drive.
