Hi all,
I'm trying to help a friend who is across the country with cold start on his modified 408.
Cam is 245/255 112 lobe sep.
BTW, he is in Florida, so cold start is still rather warm........
The TB is an aftermarket 95mm Cable driven. The IAC motor is stock GM.
The previous tuner changed the IAC steps vs effective area quite radicall. Tune attached.
The counts max in the table are now set to 102. Stock is 310.
I can see from the cold start log that the IAC goes straight to 102. Car will not start w/o adding pedal for a few seconds.
Once it warms up, the IAC counts re between 30 and 40, which is fine.
My thinking here is that no matter how much start up airflow I give it, the IAC cant add more than 102 counts. Am I correct?
I have to say that when I started with this, there was no RAF curve, In gear was set to 50g/sec across the board for in gear. P/N was set to 6g/sec.
I guessed at a curve, which helped. And even though he needed to add gas for a bit to get it running, I was able to run the Russ k idle setup and get numbers that I then put back in the P/N RAF. I filtered out TPS above .5%.
Doing this long distance is tough because I'm not hands on. But we are making some progress.
I am not sure where the throttle blade is at 0 TPS. That all may need messed with too......
My next step is to return the IAC table bck to stock and see how it does.
Am I on the right track?
Lastly, the truck is currently running MAF only, it is a card style MAF, and I know the MAF is not yet properly calibrated.......
Cold start log, config, and tune attached.
Ron
