I have a 12 camaro ss turbo 376 lsx and a built 6l80e. I have had six trans failures since i had the trans modified two years ago. I bought the pheonix package and had patc provide the transmission portion of the tune. Car runs great. makes awesome power and is tuned well engine wise with the custom 2.5 bar operating system in speed density mode. I just cant keep a trans in it to save my life. it works great for anywhere from one day to two months then starts slipping and i have to send it back. patc has been great and has rebuilt it everytime no charge but it takes awhile in shipping and stuff each time so i havent been able to drive my car very much in the last two years. im really pretty fed up. My car on low boost which is all I have run it on since the first tune I did was done makes 565 rwhp and the tranny is rates to 1200hp so im not just over powering it. My high boost puts me in the 900 range so I havent run it cause Im sure it will just burn out faster. So I talked to a big time race shop which I wont name that uses this same trans in alot of there 5th gen builds with way more power then me and the owner said right away that is was because of me running it speed density. He stated that I have to run the maf sensor to provide torque calculations to the transmission. He said he has proven many times that a 6l80 will burn up in no time with out the maf. The car does have the maf and it is tuned but I run speed density because the turbo being to close to the maf causes some bad idle fluctuations. then the owner stated i should go with sct tune and get rid of the custom os because of all the problems hp tuners have with there custom os. I hadnt heard of any problems myself. I went ahead and logged some runs to check and it seems my delivered torque follows what i would expect from the car in different driving conditions up to 640lbft i believe then it just stops. A tuner friend of mine says that is a max that is wont go above in the code. So im asking.
1 Is the maf required to calculate torque for a 6l80?
2 Is the custom os problem ridden?
3 If maf is required will it support 1200 hp as this shop owner is saying it will? I thought it was quite a bit lower then that.
ps was gonna post the tune file but i wanna ask PATC first cause they provided the trans tune and dont wanna step on anyones toes.
