Results 1 to 8 of 8
Thread: 06 F-150 with Vortech, Negative timing above or at 100kpa (0 psi)
    Mar 2013
    A-Town PA
    54
    Looking for some answers here. It looks like when I get around 1.5load (0psi,0hg) or anywhere getting close to it, the timing goes into the negative numbers. And as I get further up into the throttle it’ll just keep submarining into the negative. We seemed to have solved it by just 0’ing out pretty much every table there is and running straight off the MBT and Borderline knock tables for timing control (both the same numbers). Based off the stock 06 F-150 tune for everything with spark, is there a specific table that would be causing this? Also there is no knock detected so that’s not pulling. And we 0’ed that out first with the same results.
    I just don’t really like having to basically put all my safety spark retard settings to 0, but it looks to be the only way we could find to control spark so far and have reasonable results.
    Any ideas?
    (Stock tune included here as ref.)
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Can't help without the current tune that is having the issue
    9 sec Montecarlo SS
    Mar 2013
    A-Town PA
    54
    I was using the stock tune then just took some timing out of the MBT and Boarder Line Knock tables so it wouldn't go over what I wanted. But it would just dip right into the negatives as soon as I would get into it. so there must be something in the stock tune that is causing it to go negative timing right away. No knock or anything else that I could see triggering it.
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by Turbofox View Post
    Try setting Engine > Spark > Advance > Spark Tip-In > Tip-In RPM Max to 0.
    Eric Brooks
    HP Tuners, LLC
    Mar 2013
    A-Town PA
    54
    Thanks Eric! I'll give that a try first. I know the IAT numbers seem to be -30 and -60 etc. Will they actually pull that much timing??!! Or is it more of some type of multiplier? I'd like to correctly have it pull timing if needed if the IAT's get out of control, but if i set it for (example) -5 at 200 deg. Will it pull that amount of spark? Or does it use another table and multiply etc to pull an amount of spark?
    Oct 2014
    3
    There is a multiplier table for ACT, ECT and CHT. It multiplies those two together to give you the amount of timing it will retard from base for these conditions
    Advanced Tuner |V3nom|'s Avatar
    Apr 2009
    Denham Springs, LA
    418
    [QUOTE=Turbofox;365562Also there is no knock detected so that’s not pulling.[/QUOTE]
    how are you logging knock?
    2008 Sky RL
    Mar 2013
    A-Town PA
    54
    Just looking at knock voltage at the moment. We have an idea with using the SCT stuff where the mv is at with knock etc. Plus just logging driving around what the values are it at least give a little idea of what’s going on knock wise.
