Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: 2010 Camaro ss
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by BigDaddyCool View Post
    back in the day they used to drill a hole in it to fix the idle issues........
    Back when dinosaurs ruled the world, drive by cable/IAC setups couldn't support large cams so holes where drilled to keep the TB below the magic .65 mv idle level and allow sufficient startup/idle air requirements and allow IAC control. Today, unless you have the most radical cam in the world, Drive by Wire setups manage the TB Plate and open/close accordingly.
    Ed M
    [email protected]
    Sep 2008
    1,668
    My car is a 2009 model, apparently cant run mafless.
    Why do you think your car can't run without the MAF?
    2023 Durango Hellcat
    Jun 2009
    20
    Quote Originally Posted by mowton View Post
    Ed M
    I have just read this and couldnt agree more. I am in a similar boat i have a E38 6.0 with a 232/242 110cam im tuning, i have got it to idle nice , only issue is as soon as it sees wheel speed the idle hangs at 2000rpm until the the vehicle stops. its driving me nuts, rang Hp tuners got the drill a hole response, but im convinced i shouldnt have to. Have spent ages trying to get it to work would welcome any help??
    Cheers
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by ALPINEPERFORMANCE View Post
    Cheers
    Could use a log, but will state the obvious to start. Tuning Open Loop Speed Density, >1 bar. Your tune appears to have PE enabled (throttle = 0) for what I know is open loop idle. Assume you are doing this to overcome the large overlap in your cam. The problem is the EQ is set for 1.10 which will yield a rich mixture. Is this your strategy? If so set the 1.1's to 1.0 for a stoich AFR.
    The final idle airflow table can be tweaked to bring down rolling idle "hang" but I would assume you had already tried that. At stop, the adaptive idle function controls the air (Proportional/Integral), spark (over/under speed) and fueling (MAF/VE) and is disabled at >1.2 mph where the closed throttle rolling idle is controlled by the Min idle air and the other main elements you are tuning.
    Now, some other observations include:
    1) Open loop tables -- I recommend setting the tables back to stock and set the 1.0 in the cells above 133 F IVT and 176 F ECT. This way during cold starts and warm-up, you will be enriching the fueling to help get you to the operating temp (>176) which is where you would start tuning anyways.
    2) Set Stoich to 14.2
    Awaiting some logs.
    Ed M
    [email protected]
    Awaiting some logs.
    Ed M
    i second this. someone definitely has a big cam and wants to Open loop idle it lol
