So, I have a cam that idles at 68-70 kPA. And I want to make sure PE ramps in as cleanly as possible from lean cruise. I am setup for OLSD at idle and CLSD at cruise.
Right now, I have PE enrichment enable MAP setting to come on above 50 kPa, my Enrichment Ramp In set to 4 and TPS cold threshold as follows (stock hot table copied to cold with nothing in the 0-1600 cells):
0.0 0.0 0.0 0.0 64.0 64.0 64.0 64.0 55.0 45.0 36.0 26.0 26.0 26.0 26.0 26.0 26.0 26.0 26.0
I figure the TPS threshold is okay, but I'm wondering if I should bump my enable MAP setting to something closer to 70 kPa and whether I should just leave the enrichment ramp in to 1?
1 is how it was stock, and I'd like PE to engage as fast as possible. In older posts I saw, it was said that 1 was near instantaneous. If that's true, how can you speed it up to be faster? Also, I saw in those older threads that stock was 0.2 and that's not true in the later versions of HPT. So, I don't know if something changed along the way?
Any thoughts?
