Results 1 to 6 of 6
Thread: Write PCM error
    Aug 2010
    Detroit, MI
    932
    Write PCM error
    Attempting to do an 80e swap on a 2003 Silverado... Pulled the file, licensed it, swapped segments in 2.25, and made an attempt to write the file in and got this response:
    To rule out the possibility of it being a 2.25 issue, I tried writing the original file to the PCM in 2.24 and got this response:
    What kind of problem are we looking at here, wiring? I put a battery charger on it to make sure the battery was at an appropriate voltage and made no difference. The 2.24 scanner works fine. And as you can tell, the 2.25 writer shows the truck being a V6 when its actually a V8... Ideas? Stock file and segment swapped files attached.
    Sep 2011
    22
    did ya try writing w/o high speed just to see?
    Aug 2010
    Detroit, MI
    932
    Yeah, figured I'd give that a try too. No change.
    28,268
    Battery or wiring related issue, not tuning related.
    Hey guys I'm the owner of the truck. I took out the engine harness, went through wire by wire. Everything looked great, nothing wrong. I cleaned all grounds on the motor, the two behind the intake, and driver side block. Cleaned all of the corrosion on the pcm connectors. Very little to begin with but I wanted to be thorough. Then I used electrical cleaner on all of the connectors. There should no longer be a "wiring" issue. Is there anything else that I should pay attention to?
    Feb 2009
    1,931
    Low battery voltage.
