5.3 swap in a K-5 blazer
I just have a question about my speed sensor on my swap. I used a 700r4 with a 208 transfer case. I used a Dakota speed sensor, I know the speed sensor is giving an output. I tested it in the vehicle and got voltage out of it. My question is when I drive down the road or have my K-5 on my lift the speedometer on the vcm scanner doesn't register anything. Is this normal or do I have something turned off in my tune that doesn't allow the gauge to work? I also checked to make sure I have the correct wire connected to the speed sensor coming out of the ECM. Any suggestions for me.
