Results 1 to 3 of 3
Thread: Wideband Offset Formula in the Scanner for E10
    So, I am setting up my Ballenger AFR500 (old NGK Powerdex) for use with HPT. I know I can use the NGK PID, but I am wanting to make sure the offset is correct for use with E10 fuel so that if I setup AFR or Lamda error, it's actually correct.
    The stock formula is V/.714 + 9. Should that 9 be 8.4 because of the E10 Stoichiometric value being .6 lower than E0 fuel?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Divisor = 0.7388
    Adder = 8.742
    http://www.dsxtuning.com
    Just say no to bull s***.
    Thanks, Steck.
    So I understand why, it's because the range for AFR 0-5V is 8.74 to 15.5 (solving for either EQ or Lamdba)?
