Okay so search lambda error setup and you will have to log AFR commanded hi res, commanded lambda and log your wideband in lambda. Setup user defined lambda error and the histogram gets copied then paste multiple to the VE table in the idle area. If you command 1.00 (typically 14.68) the histogram will show say 1.02 for example. That's a 2 percent error that gets pasted to the VE table. I run my AFR around 15.2-14.8 in the drivability to run a little cleaner and better mileage. Logging in lambda is an absolute easy way for us begging rs to correct fueling issues.
I don't have the lambda option with my wide band just AFR. Is there another name for VE? I set the AFR at 15.2 and changed the low and high octane timing 6 degrees, got the truck to pass emissions but still have the fuel smell and cant get the actual AFR on the wide band higher than 14.1 school me please.
