Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 114
Thread: 5.3 first attemp at a tune may need some adult supervision
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    Check all connections for that sensor including plug, grounds anything that may be loose. If in the end all checks out then possibly sensor is failing.
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
    5BA8
    3,254
    Quote Originally Posted by Redtruck1 View Post
    Now that I have this histogram thing figured out I have noticed a problem the vehicle will not down shift or fast accelerate from time to time very random. it has a code for tps performance but it is not current says passed you think the TPS is failing causing the shifting problem?
    Should be easy enough to figure out if you're data logging.
    email=[email protected]
    Tuner Redtruck1's Avatar
    Oct 2014
    Atlanta
    61
    Now that I have the MAF close the P0106 wont go away, I tryed changing the Min Max on the MAP by 20% still setting code. The sensor is running around 71 to 79 at idle is ther a way to calibrate the MAP sensor?
    Apr 2014
    325
    From what I have read and done with mine, (running 2 bar SD) I set the low table to the minimum throughout and the upper to max. Not sure if that is 100% correct to do but it has not affected any drivability issues and solved getting codes.
    Feb 2006
    South Carolina
    1,525
    Easiest is to use the histogram that matches the P0106 table and start populating some values, then add a few kpa to give you some head room.
    Jaime
  6. #26
    Apr 2014
    325
    Now I learned something.
  7. #27
    Oct 2014
    Atlanta
    61
    Me too
  8. #28
    Apr 2014
    325
    How did you make out with the MAP code?
  9. #29
    Oct 2014
    Atlanta
    61
    Shops been covered up have to take a look this weekend stay tuned for more
  10. #30
    Oct 2014
    Atlanta
    61
    just trying to get ducks in a row for when i fix the p0106.Do I need to change the PE delay to 0 rpm enable torque to 0% and set enrichment to 4. and what about changing the band accumulator i hear about. I thought the 4L60 in my truck all ready had a corvete type style from the factory.then there is the upshift torque managment how mutch should that be reduced. just a few questions in my head.
  11. #31
    Apr 2014
    325
    PE KPA should be around 95 if I remember correct and table should be stioch divided by desired (14.68/12.5=1.17). And yes 0 the remaining columns under KPA. I don't believe the 4L60's have the stronger accumulator but read http://www.hptuners.com/forum/showth...CC-TM-(w-Pics)
    Very good walk through for trans tuning.
  12. #32
    Oct 2014
    Atlanta
    61
    This may be a dumb question what table should stioch divided dy desired be in and what does 12.5 represent.
  13. #33
    13,565
    EQ ratio is what I think you are asking about.
    So 14.68/1.180 = 12.44, or something similar. Thats your PE fueling. Also don't set the enrichment ramp in rate to 4.0, keep it at 1.5ish for NA cars.
    Stock KPA for enable is like 55 kpa, the delay is 5,000 and the enable tq is 100%.
    I set them to like 75 kpa, 1500 rpms and 50-75% enable torque. The factory throttle % is 90%, lower it to what you want.
  14. #34
    Oct 2014
    Atlanta
    61
    NA (Normally aspirated)?
  15. #35
    Apr 2014
    325
    Naturally Aspirated, and sorry I did give you what is normally set as FI settings for PE
  16. #36
    Oct 2014
    Atlanta
    61
    I got 1.126048 for the EQ ratio. Do I populate the whole EQ string with this number or do I use this as a multiplier.
  17. #37
    Oct 2014
    Atlanta
    61
    MAP code seems to have been fixed last two test drives the CEL has been quiet. Thanks for the input now on to better tuning.
  18. #38
    Apr 2014
    325
    I believe if I understand your post correctly that 1.126048 is your multiple by percent value.
    Glad to hear you cleared up the codes.
  19. #39
    13,565
    1.126 is pretty lean if you ask me, thats right at 13 afr. I would go richer.
  20. #40
    Apr 2014
    325
    I think I got lost on that, is the 1.12 an error from logging or just the actual reading?
