Results 1 to 17 of 17
Thread: A/F Ratio Histogram?
    Nov 2008
    Hampton, VA
    75
    Hey guys. Got a question about tuning my car. I have a WB O2 sensor that I am datalogging into HPtuners and when my car comes into boost the AFR is pretty rich like 10.3:1. I want to bring this up a tad so I need to tune my VE table some. Is there a histogram I can use or make that will logging this rich AFR in the histogram and show me exactly which cells to alter in my VE table? Thanks in advance.
    I have to agree, I think the histogram/PIDS are the most confusing part of HPT. I wish I could find a good "how to" on making/using histograms/PIDS/configs.
    Curious, are you using BE on your setup? Is this something you can just change your BE/PE table to dial in, or is your VE off?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by tording99z28 View Post
    Have you seen Greg Banish's DVDs by chance? He goes through that type of thing in detail.
    The short answer is yes. You can create a variable that is the error between commanded AFR (or Lambda) and actual and use that on a histogram with the same x/y axis as the VE table to make it easy
    Nov 2008
    Hampton, VA
    75
    Quote Originally Posted by rpturbo View Post
    Yes the PE table could be used to dial this in probably but I am pretty sure the proper way is to dial in my VE table. I am not really sure why I think this just seems to me that changing the PE table would just be a work around when the real issue is the VE table needs to be corrected.
    No I have not seen Greg Banish's DVD on this but I would love too. I have a histogram that is already built called AFR Error % so I am guessing this is what you are talking about but I was confused about the error %. What is the error % measured against. Based on your comment I guess commanded AFR. I know what my commanded AFR is during cruise but not sure how to tell what it is during WOT. Is there a table somewhere to change this?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    There's a symbol to the right of the numbers for the different histograms where you can go in and see what all of the histograms are being built from.. so I'd start with seeing what that histogram you are looking at is
    Remember you need to add whatever you want to work with to the "table display" view first, I think anyways
    Are you using the default config that comes with HP tuners or you have downloaded someone else's, or changed something on your own? I ask because I highly doubt anything would be setup to compare wideband readings vs. commanded AFR/Lambda values correctly without you setting it up specifically to your setup. The default config def. doesn't come setup that way
    Nov 2008
    Hampton, VA
    75
    Yes I had a local guy tune my car last year and it is his config file. I am tired of paying someone each time I want to tune though so I am doing it myself. I am a pretty smart guy when it comes to cars and computers so I know I can do it, just nerve racking when dealing with so much power but have to start somewhere. It is a SD tune so no MAF to worry about so fairly simple and I understand the concept just wanted to see if there was an easier way to overlay the rich WOT condition on top of my VE table to make edits.
    Apr 2007
    Toronto
    88
    so make a pid to show wb vs commanded and lay it over the ve table histogram
    01 vert m6 with forged main shaft 377 ls2 block forged etp 225 cam motions 228/228 twin garrett gtx 3076 alky control twin nozzle bear brakes,calloway coilovers, hre 19/18 with hoosier r6 .
    Sep 2008
    1,668
    I have a histogram that is already built called AFR Error % so I am guessing this is what you are talking about but I was confused about the error %. What is the error % measured against. Based on your comment I guess commanded AFR. I know what my commanded AFR is during cruise but not sure how to tell what it is during WOT.]
    If that histogram is populating when you're logging, then you're already logging the commanded AFR also. On the table (not the histogram), you should see something like "Air Fuel Ratio Commanded Hi Res". This takes into account the PE and/or BE values commanded. After that, if you've got HPTuners Pro and you're logging your wideband as "AFR" then the default config will work. Histogram 6 should show you your actual recorded AFR, and histogram 7 should show you the % error between what the wideband is measuring and what the vehicle is commanding.
    2023 Durango Hellcat
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yes, it should be comparing the commanded vs. actual read by the wideband
    Read up on power enrichment table. Basically the computer takes the "normal" stoic AFR and divides by the power enrich ratio when you are in power enrichment mode (PE). WOT is def. PE mode unless someone has done something dumb.
    So if you're set to run 14.7 stoich normally and at 5000 RPM's you have a PE ratio of 1.3, the car should be running (well, COMMANDING) 11.3 AFR@5000 or if you're using Lambda, .77 Lambda. If the VE or MAF tables are wrong then the actual could be different, thus the purpose of a wideband
    The error # in the histogram should take all of this into account and give you a final error between the commanded AFR and actual, regardless of whether in PE mode or not
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Also, someone linked to this in another thread which is probably a decent place to start:
    http://www.redlineforums.com/forums/...ve-tuning.html
    Nov 2008
    Hampton, VA
    75
    Ok I think I got it. So the only change to the Commanded AFR is the addition of the PE table when in PE mode. So my commanded AFR is 14.6556XX and my PE is 1.3 then just take the Commanded AFR and divide it by the PE ratio and that is the commanded AFR for WOT? That makes total sense. So what is the proper way to tune for WOT? Change the PE table to get A/F's aligned where you want them or change the VE table to do the same thing? They should both have the same affect but I am sure one is better than another? I have posted my logs and tune and config file. Also my car is seutp in Speed density so there is no MAF to mess with any of the fueling.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You want the VE table to be correct first.. for the lower RPM tuning you can set PE and any other enrichment values to to 1 first, then adjust the VE table so that the commanded/actual end up being the same. That gets a little trickier with WOT since you don't want to run 14.65 at WOT
    After the VE is correct, when you change the PE back to something greater than 1, the computer shouldn't have any trouble calculating everything correctly and delivering exactly what you've asked for
    Your MAF table needs to be right too, if you are using a MAF sensor
    Nov 2008
    Hampton, VA
    75
    Ok I understand what you said above and I have done that. I have cruised around and adjusted my VE table so that at cruise and lower rpm's my STFT's and AFR error is very low +- 5. I also changed my PE table so that my commaneded AFR at WOT is going to be 11.2:1. I just went and did some datalogging at WOT and for some reason for the first half of my WOT my commanded AFR is 11.7 and then it drops to 11.2 right where I want it to be. What is causing the commanded AFR to be 11.7 at first? Is there a table somewhere I am missing causing this? I have attached a log and you can see there are 2 spots where I went WOT and in both times the commanded was 11.7 at first then dropped to 11.2.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Post the tune as well--you only posted the log. Sorry for the slow response
    Also, what are the specific RPM's where that happens?
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    There needs to be certain criteria met to enter PE, BE such as MAP KPA etc. Depending on application N/A, F/I you adjust the KPA to accommodate. Example of my 6.0 when N/A the KPA was 55KPA and the throttle position was 85%. My F/I application the KPA is 105 and throttle is 40%. That's what logging does for you. It will help in the process of fine tuning where PE and BE would come in. There is also RAMP IN RATE which will tell the computer has fast to bring the ratio's to what your commanding.
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by Cyrperformance View Post
    Indeed, I was going to say basically the same. Which is why I was asking for a copy of the tune and specific rpm's
    Apr 2014
    325
    Also whatever you want to show in a histogram HAS TO BE IN THE TABLE. You were correct when you stated just the I think anyways may get lost.
