Ok I started getting frustrated with the 2 VE Tables while tuning my 2000 Vette, so I asked about switching to the newer OS Style I had in my 2001 Vette that I no longer have. I was told it would work since I owned the liscense to both but that I should try the Enhancements since they were free.
So I attempted to load the 1 Bar Map Enhancement using my 2000's tune file and it told me I needed to buy 2 more credits.
So i gave up and went to bringing everything over from my 2000's tune to the 2001. Once done it loaded just fine. Then I went to start it and found the first problem.
It would start but shut right off even with gas input. If I switched back to the old tune no issues... so I tuned off VAT's and it started right up. I tried using the Relink VATS option under flash and it said it was successful but it still would not start with it on... However with it off the security light in my cluster is on and it drives me nuts.
Next I started tuning and it was great everything was working besides the VAT/Security until I went to put my convertible top down.... I would push the button and it would not pop. Again testing I loaded the old tune and it popped no issue... I saved a 2002 Convertible Vette's file but of course I would have to license that to use it... I don't want to do that until I know I am not going to keep find more little issues.
Then on the way home I found my next issue, I entered all my gear ratio and tire size changes to match the 2000 Vette and the Speedo and HUD read correctly. But when I went to turn on Cruise Control at 82 it said I was doing 42..... and proceed to try and slow down when I let off the gas...
So I am a little confused and at this point seriously questioning if I should just keep trying to find out why I cannot load the 1 Bar Map enhancement or get the license to the 02 Vert's file... but I am worried I will have more problems going that route.
Anyone mind shedding some light on this for me? Thank you
