Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
I don't understand how a zone adjustment will help? I want the GMVE table to calculate what I pasted in (should be simple, has worked fine since this newest beta)
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
My GMVE values go from 2200-2500 I. The zones I'm working at to -1800 to -500
That's a HUGE distortion
14 Gen 5 Viper
Got any screenshots or tune/values you're plugging in so we can try to help?
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Ben how are you data logging gm ve for the c7's? I know they're all map/baro instead of just map axis. Only reason I ask is because new scanner doesn't seem to work with the map/baro and not sure how to set up 2.24 to do it.
~Greg Huggins~
Ben Charles, this is exactly the issue I was having a while back. It corrected itself after a new version came out, it sounds like it broke again. It's like the auto-smoothing it does when you apply changes is messed up.
No screen shot unfortunately, Higgs is right the "code" must be broken on yesterday's beta (updates daily) so I just stopped SD tuning and went back to Mass air.
I'm using the 2.24 scanner, don't really care for the 2.25 scanner.
I setup pressure ratio as [SENS.30]/[PID.51]
I think that's the equation for map divided by Baro
Also figured out a trick way to dial in the Driver demand tables
I was seeing throttle percents not matching and now they are right on top of each other
14 Gen 5 Viper
There is a Pressure Ratio pid, you dont have to calculate it.
Yes, what little I've used the 2.25 scanner hasn't been very pleasant. I was glad to see the ford pids added and working correctly. Other than that, not really a fan.
Don't guess there's any chance of sharing your driver demand logging setup? All though I imagine you could do the same thing that you have to do for Fords and then add a touch and be spot on?
I just hope the vve isn't making the "city blocks" like it was a few weeks ago. Pulled my hair out for half a day trying to figure out what I did wrong in my base tune that was causing a false 2800 rpm rev limiter... That particular car got the stock vve left alone unfortunately...
~Greg Huggins~
I've found that if the distortion falls on a zone boundary, if you move the boundary between the two (or more) offending zones that the distortion is notably less. You didn't see this with BlueCat because it automatically adjusted the zones to best fit the VVE table. One of the features I've requested be migrated to 2.25
Has anyone written a procedure paper on using V V E editor in 225?
Change cells
Hit calculate
Procedure complete
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
[email protected]
AH yes, sorry. My bad.
Though in all seriousness.. is there a way to change where the different zones are? I haven't messed with that but figured there had to be
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Engine > Airflow > Dynamic > Zone RPM Boundaries
Engine > Airflow > Dynamic > Zone MAP Boundaries
2015 Cadillac Escalade ESV, 6.2L L86, 6L80e - AFM disabled
I make open and close the same values.. I don't even touch the DOD VE tables due to usually just disabling DOD
[email protected]
