Results 1 to 5 of 5
Thread: Help with part-throttle surge/drivability problem (2008 L61)
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    I've had this surge for a while and just lived with it. I don't want to anymore. It is a part-throttle surge around 1400-1700RPM both around 25-30mph and around 40-45mph. It seems to happen worse when letting off the throttle once I reach the desired vehicle speed. Anyone have ideas? My MAF is dialed in well. Down to +/-1%. I have already tried things and here's what hasn't worked.
    OL vs CL. Open loop does nothing to remedy.
    O2 switching voltages. Didn't expect it to do anything but tried anyway. Have since put it back to stock.
    Removed 2-3* timing from surge problem area rpm/airflow
    Throttle follower values.
    Attached is a config and a log. The MAF error isn't perfect on this log but it shows the rpm surge better than any of the other logs I have. I logged tons of table display stuff too. Is this mechanical???
    2008 Pontiac G5 2.2L (main oil seal became a crunchy Autumn leaf, RIP)
    2016 Fiesta 1.0L Ecoboost - Project "not-so-detestable"
    Apr 2013
    El Paso, TX
    297
    SOLVED SOLVED SOLVED!
    It was the shitty stock TCC duty cycling.
    Great job!
    Mar 2015
    Hey did you just replace the solenoid?
    Apr 2013
    El Paso, TX
    297
    Nope. Trans to this day is 100% from the factory except the tune. All I did was set PWM TCC duty cycle to 100% max and 90% min and disabled lockup in third gear because it snaps your neck if you leave lockup enabled in third.
