Results 1 to 12 of 12
Thread: AFR control
    Sep 2014
    9
    AFR control
    Anything I do , do not work to control my mixture at idle , it always get to 12hight ,13 low after warmup
    I change VE # and injectors size, it always go back to 12-13
    Its a 3 bars setup with 95pounds injectors lsx 427
    Maybe I forgot something in start tune ,
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Go to Fuel>transient Fuel Qualifications>Min Fuel Milligrams and halve that field.
    Russ Kemp
    Sep 2014
    9
    Afr
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Tanks will try it in morning .
    Aug 2014
    6
    Any luck
    Sep 2014
    9
    Yes , its better , but still don't have complete control.i did halve the Min Fuel Milligrams , and get to 13.5 and cut again and get to 13.8
    When I use the fuel trim in VCM controller , I need to get to 13 minus to get to 14.7
    I didn't have much time to play with that today, I will do tomorrow on dyno.
    Thanks to Russ Kemp for your help ,
    Dec 2005
    Regina, Sask.
    4,214
    Your IFR table is set up for a vacuum referenced fuel regulator, but you offset table isn't. Copy your 0 vacuum kpa column and paste it into every column to the right of it.
    Any chance you have a cam sensor code?
    Russ Kemp
    Sep 2014
    9
    Just done it and didn't change , still have same AFR
    Don't have cam sensor code .
    I keep looking ,
    Thanks again
    Dec 2005
    Regina, Sask.
    4,214
    Then zero the Min Fuel Milligrams field.
    Russ Kemp
    Sep 2014
    9
    I tried to send you a private message , but your box is full
    Sep 2014
    9
    Found the solution.
    Going back to EFILIVE
    Sep 2008
    1,668
    What's the solution you found?
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    Sep 2014
    9
    Few pulls todays belt slip after 5000rpm ,
