Looking for some guidance in what to adjust for when switching to E85 from Regular 93 octane? Any help will be greatly appreciated.
Fuel pump if pressure drops, E85 needs ~30% more fuel. Log IDC.
Thanks for your help through Email... I will keep an eye on the duty cycle and pressure. Hopefully I can pull it off. If not what it the best solution for a drop in tank pump for replacement, plus with out going supercharged what size injectors would be safe without over doing it?
I overtax my Livernois twin setup blown on corn but it might be large enough NA, I'd recommend dropping the tank and doing a Squash system with ID850's if you are a 5th gen Camaro.
I'm *STILL* holding out for a Squash returnless system if it ever gets released.
