Results 1 to 3 of 3
Thread: V3 Supercharger ls1 2bar limp mode
    Oct 2008
    Perth Australia
    161
    Need help
    Ls1 VZ Commodore with V3 supercharger going into limp mode after hitting 4000rpm at WOT.
    Wont do it at part throttle.
    What am i missing ?
    Check your P1514/0068 tables under engine diagnostics ==> airflow. Im assuming you're getting a DTC that relates to this table. If not put up log/tune.
    Oct 2008
    Perth Australia
    161
    Quote Originally Posted by SSUte01 View Post
    Yes i had to max out that table being a VZ with electronic throttle body, and that solved that issue, cheers.
    New issue now is some surging past 3500rpm and some slight popping sounds also past 3500rpm
