I have 250,000 km on my stock 6.0 L motor. I know there is a leak in the exhaust manifolds/ head mating surface. I suspect it is running falsely rich because of an influx of fresh air. I was toying with temporarily disabling the O2 sensors, and just letting the computer run from it's baseline maps for a bit. However I was curious, with a motor which is very worn in, is it going to run richer then it did when it was new. Or put another way - if you did a trial, and took a motor with 20,000 km on it (broken in - but still new), and let it run on perfectly tuned maps (0 short or long term trims) perfectly stoich, and then you put 10 years and another 250,000 kms on the motor - compressions down in theory, sparks maybe a little weaker, exhaust doesn't flow as well as new, etc. - would you expect it to run richer or leaner?
I'm just curious if anyone has an opinion/ facts on the matter.
My thoughts were it is less efficient in general, so more unburnt fuel heading out the tailpipe -> ergo richer.
Or an opinion, other then fix the air leak, as far as disabling the o2 for now and letting it run straight off the tables. When I reset fuel trims, and was in closed loop I was running .072- .74 volts, foot to the floor, or cruising - however I'm guessing air leaks had a lot to do with this.
If anyone wants to see what a vehicle like this runs like I have attached a log. I reset the fuel trims multiple times. At 2.5 mins, then at 3.5 ish, I reset and turned off trims. Before this scan the fuel trims had been reset a short but forgotten time ago. I wish there were a way to go backwards in scans, rather then restart all the time.
black chevy trip around the block w speedo changed trip 2.hpl
