2003 Truck 4.8 Idle problem after cam and head install help!!
I just install a cam ls1 XR275HR-12 from comp cams the heads are 853 stock Camaro heads here is the stock tune the truck stays on but dies when in gear idle is bad check engine light turns on with p1060
Try this, its your file so write calibration will be fine. You can use compare function to see what I changed. Did you mean p0106? If its still setting after this then go to engine diagnostics and increase/decrease min/max values.
truck idles much better but is running lean is there anything i can do to make it run a little richer Im going to change injectors soon but i got to drive the truck
