I have a heavily modded 06 silverado I have been having an issue putting nitrous to. Basically I launch the truck-> it goes to the point where the wide open throttle signal turns the nitrous on then the truck falls on its face then will start the rev up again and will spray through the run. Which can be seen by the attached logs. In the run 2 log the throttle was let off for spinning. The truck runs great on the motor and can be seen in that log file. Attached is also my tune if anyone has any idea on what it could be.
At first I thought the x link for the throttle body could be the reason for this happening but I talked with the manufacture and learned the 0-5V signal pull for the throttle position doesn't go through the xlink.
Any help would be appreciated.
Leakesville_motor_run1.hpl
mobile_nitrous_run1.hpl
nitrous_mobile_run2.hpl
Truck_200shot_082214.hpt
