Results 1 to 9 of 9
Thread: how to use 4l60e to 4l80e file
    Nov 2013
    marksville louisiana
    32
    i need to do a seg swap for my 4l60e to 4l80e but cant find an OS: 12593058. i found that u can change a table from 4l60e to 4l80e under trans/autoshift/general is this all thats requied now instead of seg swap thank in advance.
    Nov 2013
    32
    Wow no body knows
    2003 swb single cab
    lq4 6.0 243 heads mill .30
    comp cam 224/228
    1 7/8 lt headers
    fast 36LB injectors
    4l80e swap 3500 circle d converter
    13,585
    Email support with your info, they might have a file handy that they can use. Not everything is in the respository.
    Nov 2013
    32
    I tried but i cant send my file through hp to them. I sent them e mail hope they respond
    2003 swb single cab
    comp cam 224/228
    1 7/8 lt headers
    fast 36LB injectors
    Aug 2014
    7
    I think you can just download a tune from the repository with a vehicle that has the trans you want and load it as compare file, then copy and paste from the downloaded one to yours. no need for a seg swap.
    I'm new to tuning, and could be wrong, but seems like it would work. Good luck
    13,585
    Segment swap is the correct way, it won't be right if you just copy and paste as all the tables for a 4L80e arent there unless you segment swap.
    Nov 2013
    32
    I downloaded beta version and did a seg swap but thanks for replies
    2003 swb single cab
    comp cam 224/228
    1 7/8 lt headers
    fast 36LB injectors
    Tuner Joe6pt0's Avatar
    Mar 2006
    Indiana
    141
    Beta has seg swap built in to it?
    Nov 2013
    32
    Yea but i still havent learned what to tune after the swap
    2003 swb single cab
    comp cam 224/228
    1 7/8 lt headers
    fast 36LB injectors
