i need to do a seg swap for my 4l60e to 4l80e but cant find an OS: 12593058. i found that u can change a table from 4l60e to 4l80e under trans/autoshift/general is this all thats requied now instead of seg swap thank in advance.
Wow no body knows
2003 swb single cab
lq4 6.0 243 heads mill .30
comp cam 224/228
1 7/8 lt headers
fast 36LB injectors
4l80e swap 3500 circle d converter
Email support with your info, they might have a file handy that they can use. Not everything is in the respository.
I tried but i cant send my file through hp to them. I sent them e mail hope they respond
2003 swb single cab
comp cam 224/228
1 7/8 lt headers
fast 36LB injectors
I think you can just download a tune from the repository with a vehicle that has the trans you want and load it as compare file, then copy and paste from the downloaded one to yours. no need for a seg swap.
I'm new to tuning, and could be wrong, but seems like it would work. Good luck
Segment swap is the correct way, it won't be right if you just copy and paste as all the tables for a 4L80e arent there unless you segment swap.
I downloaded beta version and did a seg swap but thanks for replies
2003 swb single cab
comp cam 224/228
1 7/8 lt headers
fast 36LB injectors
Yea but i still havent learned what to tune after the swap
2003 swb single cab
comp cam 224/228
1 7/8 lt headers
fast 36LB injectors
