Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Calling Speed density Gurus, help with 2bar custome OS
  1. #21
    Apr 2010
    Sunshine Coast Queensland
    26
    Hi mate,
    I was just looking through your logs, and every time it falls on its face the throttle shuts. Is that you getting off it, or is the TRC on or something?
    02 BA XR6T, Crow Race Valve springs, centre muffler removed, 60lb siemens and stage 2 PW cooler+UB intake, 307RWKW at 12psi. SOLD
    99 Nissan Patrol, l77 ls2 + 6L80 swap SOLD
    2013 Gen-F HSV Clubsport R8 - Work in progress
  2. #22
    May 2007
    26
    If you look further you'll see where I made longer pulls. I would run out of room on the road and coincidently have to get out of it at that time. There are only a couple of long 4th gear pulls in that log. I need an eddy brake dyno in all reality.
  3. #23
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    Quote Originally Posted by Maxspeed96ct View Post
    One other thing, in your open loop Eq ratio , you have 10.0 . Was that a accident ? Did you mean to write 1.0 ?
    I'm going to step in here and say every GTO tune I've seen has 10.0 as the open loop EQ.
  4. #24
    Oct 2008
    12
    Quote Originally Posted by CatnipG5Bandit View Post
    my gto tune shows 1.0 for open loop EQ
  5. #25
    Jul 2014
    218
    some set this to 1.0 in speed density , i guess i was thinking of gen 3 tuning not gen 4
    Looking through the repository most gtos are 10.
    It was just something that caught my eye ..
    check those maf DTC's though
  6. #26
    May 2007
    26
    Mine was 10.0 stock, didn't change it. Now, for the rest of the story. Changing pe vs. tps to 5% fixed the pe enable. I read a thread that talked about this table not actually coinciding with linear tps but was more about the opening area of the throttle. I remember having to do this on my 2010 Camaro with the Maggie to get it to come on, different ecu but genIV so they're similar in some respects. Also lowered the test for maf fail to 300 rpms now maf has failed. Time to really massage the main ve table. My boost afr is really rich but at least it's coming in good at 100kpa, it's now map based which I like. My afr in boost starts at 11.7 and finishes at 10.5. I'll post the last log and tune (not final by any means) shortly when I get back to my laptop. Thanks to everyone that contributed. I'm learning a lot. Hopefully I provided something about the pe enable. It appears to be something not everyone knows about.
