Results 1 to 5 of 5
Thread: ID1000 injector values for Ford BA/BF Falcon
    May 2011
    New Zealand
    34
    Hi guys
    Can some one post up the ID1000 injector values for Ford BA/BF Falcon, or a tune with them in so i can copy the values
    Ive tried copying them from ID website but the values don't make any sense to me
    Cheers
    Aug 2012
    Melbourne Australia
    344
    Off the Injector Dynamics web site, selecting the "Return Style System" tab and plugging in 4 bar pressure (58.015psi) you will get the following numbers:
    Code:
    Breakpoint (lbm/cyc)			0.000027
    Hi Slope (lbm/sec)			0.031774  * 3600 = 114.3864 lb/hr
    Low Slope (lbm/sec)			0.035023  * 3600 = 126.0828 lb/hr
    Minimum Pulse Width (sec)		0.000272  * 1000 = 0.272ms
    15.00	0.001107 *1000 = 1.107 ms
    14.00	0.001215 *1000 = 1.215 ms
    13.00	0.001346 *1000 = 1.346 ms
    12.00	0.001497 *1000 = 1.497 ms
    11.00	0.001682 *1000 = 1.682 ms
    10.00	0.001974 *1000 = 1.972 ms
    8.00	0.002987 *1000 = 2.987 ms
    As you can see I have done the conversion for the numbers to put into a Ford tune. Note for the slope values you could have cycled through the units in HP tuners to get the same values used in the ID spreadsheet.
    You should check I have copied the numbers correctly yourself and validate them. I would love to use these injectors but cannot.
    Darryl.
    When it comes to ID injectors, don't hesitate to email the guys there. They generated custom data for my L67 (3.5 Bar system) and I ended up with copy and paste simple numbers.
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    If u cant work out the very simple values i feel u have bigger issues than copy n pasting
    The id website has a brilliant "plug n play" calculator where it spits out all the data you need to get you running
    BUT ! This is not your final figures, you still need to scale them in correctly otherwise your lambda table will not be correct for one nor will your LHIT/ cruise be accurate
    When you start asking for things that are more than available and to cut n paste it shows that the understanding is lacking a bit and may just run with posted scalers that is in fact very un cool for obvious reasons
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Aug 2013
    Melbourne , Victoria , Aust
    29
    Hi DarrylC , your maths is TOTALLY correct I love my cut'n'paste feature I'm getting better with age.
    ID1000 Ford Injector Characterization - 0% [email protected](4Bar)RTS
    Enter Ethanol Content= 0%
    Enter Base Fuel Pressure (psid) = 58.02psi(4Bar) for return fuel system
    Scalars
    Breakpoint (lbm/cyc) = 0.000027(lbm/cyc) =
    Hi Slope (lbm/sec) = 0.031774(lbm/sec) = 114.3864 (Ib/hr)
    Low Slope (lbm/sec) = 0.035023(lbm/sec) = 126.0828 (Ib/hr)
    Minimum Pulse Width (sec) = 0.000272(sec) = 0.272 (msec)
    Stoichiometric A/F Ratio = 14.64:1 AFR
    Offset vs Battery Voltage (sec)&(msec)
    15.00 0.001107sec = 1.107msec
    14.50 0.001159sec = 1.159msec
    14.00 0.001215sec = 1.215msec
    13.50 0.001278sec = 1.278msec
    13.00 0.001346sec = 1.346msec
    12.00 0.001497sec = 1.497msec
    11.00 0.001682sec = 1.682msec
    10.00 0.001974sec = 1.974msec
    9.00 0.002431sec = 2.431msec
    8.00 0.002987sec = 2.987msec
    7.00 0.003516sec = 3.516msec
    6.00 0.003966sec = 3.966msec
    Cheers
    PS - Same values for FGXR6T - S1 & S2
    Last edited by FPV_GTp; 01-04-2015 at 05:28 PM. Reason: forgot to list numbers & PS
