Hey guys. I have a friend who turbo'd his truck. He's having an issue with part throttle enrichment. He has an external wastegate so boost control is tough since there is no factory boost controller (currently using gate pressure of 5psi).
The main issue is part throttle tuning. Is there a way to start enrichment based off of load vs rpm, or some type of load vs open loop fueling? WOT enrichment is fine. Afr drops to target as it should. I have HPTuners and am going to tune him but I need feedback before I start. I haven't heard back from HPT yet. Thanks!
MODS:
Gt4088r turbo
72lb injectors
38mm wastegate
3 bar map (from zr1)
Blow thru maf sensor setup
