Results 1 to 18 of 18
Thread: WTF?! MAP Latency!!!
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    I have a new combo I am working on and am seeing .1 - .2 seconds latencty or delay in the map sensor readings?
    Has anyone had issues / concerns / data about this?
    E67 Erod computer and harness
    MAP just behind the throttle.....
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    13,576
    How many things are you logging in the table??
    Having alot of stuff in there, like anything over 24 will slow down the readings alot.
    Mar 2006
    sunny So Cal
    292
    seeing a decent OFFSET between Throttle openings and changes in the MAP
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    This is a Major issue for any SD LS!!
    in the last 24 hrs I have tested stock and modified cars!!!
    Look at something in your bay and report back!
    I dare you!
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    vamnumber2 whackasaurs AD.hpl
    here is a log off a stock 2013 C6 DS GS
    NotoriouSS TAD
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    What exactly is your basis for saying there is a delay? There is a manifold fill time dictated by fluid mechanics.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2006
    sunny So Cal
    292
    DStech,
    You are a super sharp guy and I have mad respect.
    take a zoomed in look at the log I posted and tell me what you see.
    that is a 100% mechanically factory stock C6 DSLS3 GS
    NotoriouSS TAD
    Mar 2008
    St. Louis, MO
    4,860
    I understand that, but air is a fluid, and it cannot instantly pressurize a given volume. I would never expect it to instantly track actual throttle position.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Whatever causes it, "DELAY" is the proper term and problem, but for whatever reason the cylinders see more air before the MAP see's it, and goes lean... so delay is a big problem.
    I also had this problem, people with M6's will notice it more than the auto guys of course. GM realized it too and the ZL1 and other LS3's uses TPS to enable PE, not MAP since it's too slow to respond (delayed) (MAP enable real low, like 15kpa)
    I just checked a handful of GM LS v8 files dating back to 2002ish... they all enter PE based on TPS, not MAP. In fact, some of the older ones basically go into PE based on RPM since MAP = 15kpa, TPS = 3%, above 5000rpm.
    That's not a bad strategy... maybe I'll change to that.
    ZL1 Wheels/Tires
    Mar 2012
    Detroit, MI
    1,320
    then theres the Whippled GM Copo seen at the Woodward cruise... two old school map sensors (giant ones from the 80's and 90's! Wonder why they didnt use the newer ones... Any why are there two? from what I can tell is one is on right side, and one on left side of the base of the Whipple.
    ZL1 Wheels/Tires
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    What is the problem with that delay? it's completely normal
    As DSteck said, air is a fluid and you can't expect an instant and linear response in its behavior.
    The air is flowing into a closed space where the cylinders are causing a vacuum, of course the cylinders will fill first, until then the pressure inside the manifold can raise. That is the purpose of a MAP sensor, because TPS can't accurately predict all possible situations much less when the engine has transitory states, like going from idle to a sudden WOT. TPS is not a good method to calculate airflow but MAP is.
    Check if MAP reading is correct, then datalog only the PIDs you really need. Nothing to worry about
    9 sec Montecarlo SS
    Mar 2012
    Detroit, MI
    1,320
    Quote Originally Posted by Montecarlodrag View Post
    Running lean under boost is nothing to worry about? LOL
    Just enter PE early, based on TPS since the MAP delay cant be fixed.
    Also setting PE MAP enable to 85 helps... but then your in PE early under normal driving.. So TPS/RPM is the way to go (as GM does it, with a 100,000 mile warranty).
    ZL1 Wheels/Tires
    Mar 2008
    St. Louis, MO
    4,860
    You would benefit heavily from understanding what transient fueling is and how evaporation and wall wetting come into play.
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    Quote Originally Posted by 10_SS View Post
    Transient Impact Factor? Charge Temp Bias vs Filter Rates........ both can be tweaked to create a richer response to cover x issues........ Maybe 'over compensating' on VE just outside WOT where your about to enter full throttle to enrich the mixture....
    Enter PE SUPER EARLY and have a slower enrichment rate? Set a higher enrichment/pe/afr value to ensure on full throttle gear kick backs it stays within certain AFR's......
    Dont mess with GM's setup? ....... MAP is SLOW, its a fact it wont change. Question is how can you make it work for you......
    If you want to try and make a MAP based pe setup......... set 5% Throttle by 70kpa....... across the board...... If you look across alot of tunes you will see that on the ls2 & ls3's 70kpa seems to be the average end spot for any type of fuel compensation........ past that its mostly the same.
    My 2 cents.......... and oh yes tuning is frustrating
    Transients ........ Feed me more.
    2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
    Mar 2012
    Detroit, MI
    1,320
    I've tweaked the crap out of those settings... In the end, they only fill the gap where PE delay due to MAP occurs. Fix the problem correctly by removing the PE delay.
    Quote Originally Posted by BigDaddyCool View Post
    If you want to try and make a MAP based pe setup......... set 5% Throttle by 70kpa....... across the board...... If you look across alot of tune you will see that on the ls2 & ls3's 70kpa seems to be the average end spot for any type of fuel compensation........ past that its mostly the same.
    Not sure I understand this. I assume this is based on NA cars. I had mine set to 5% and 90kpa and would enter PE far too early on my boosted 2 bar SD tune.
    Mar 2008
    St. Louis, MO
    4,860
    Lol. Ok. The rest of the world makes it work.
    Sep 2008
    1,668
    If I did this, I'd be in PE...almost 100% of the time.
    2023 Durango Hellcat
