I have a 99 LS1 out of a camaro with no rear O2's, no EGR, Bosh 3 modified injectors 30 lb and a Lunati cam: Advertised Duration (Int/Exh): 283/283 Duration @ .050 (Int/Exh): 221/221 Gross Valve Lift (Int/Exh): .558/.558 LSA/ICL: 114/110 I entered in the injector flows and modified the VE. When it did run it ran very rich and burned your eyes. I tried using a stock tune and it did't start. I also tried the idle tuning how to with no luck. Could the plugs be fouled?
Have you messed with idle airflow ?
Josh Performance Tuning (956)784-0059 https://www.facebook.com/joshperformancetuning
