I've been on this site for a little while mainly reading and researching, I just wanted to post my tune and log just to see what yall think so far. I'm still in the "tuning" process so i know its no where near done. Just wanted to see if I am going in the right direction.
Specs:
Stock LQ4 engine with rod bolts
BTR dual valve springs
TU2 cam
88Lb deatsch werks injectors
Dual 044 fuel pumps (one is only hooked up)
AEM AFPR
S480 turbo
ls1 intake manifold
t-56 w/ LS7 clutch and flywheel
Ive been playing with the VE table, (Which I haven't Smoothed from the last update) haven't really did too many WOT runs yet, (keep blowing couplers) I'm not too sure where to begin on my spark table. I have borrowed a few ideas from the repository. It idles and drives fine. Just wanted to go into the tuning for boost next, but figured I need an outside opinion until then. Any opinions and critiques are welcome
Your VE table is all choppy with major issues. It will have smooth transitions if you are adjusting correctly. Are you
certain your wideband is set up correctly and the sensor itself is working properly?
I know it's rough. I haven't smoothed the last "update" out yet. I figured I would give the raw results. Yea I'm sure my wideband is set up. What's screwing me up is when I'm letting off the pedal or just simply cruising, my WB is leaner then when I'm on the throttle. Which is why I set up two more histograms that are based off of the TPS. That tune isn't currently loaded on my car yet. I'll do that after I smooth it out
