I have installed an L76 (LS2) / 6l80e combination in a 1966 nova and the transmission won't up shift accept during normal driving. When WOT IT WILL NOT UPSHIFT..... PLEASE HELP!!!!!!
Im a newbie still but, post your tune. What area are you from? Car sounds familiar. Are you in Maryland?
No, I am from Texas, here is my tune. I am new to this and any help you could give would br greatly appreciated!
Your pattern B has all 0's in the tables....
Okay thanks, I'm new to this, any suggestions to what it should be?
Disregard last post, I downloaded a stock 2009 G8 tune and compared it to yours and apparently the G8s do things a little differently than the Camaro/corvettes. The one thing I did notice is that you changed your shift pattern type under the transmission general section. I would change it back to the stock setting:
Pattern A = pattern 1
Pattern B = normal
In that section, it recommends to not change those settings. Try that and see if the shifting changes.
Thanks Farm Truck, I will try your recommendations!
