Hello every one, I'm pretty new to HP Tuners, cam over from the import world a few years ago, on my second vette, first auto car I've ever owned.
2005 Corvette, LS2 w/ 4L65E Tranny.
Upgraded to 3.73 Gears
3400 Stall Circle D spec 9 3/4" stage 1 Converter
Bullet cam:
Intake Exhaust
Duration @ 050 225 232
Lobe Lift Separation 115
Duration @ 006 280 290
Gross Valve Lift .575 .570
Degree Intake Lobe to RG 111
Had a quick tune from a personal contact, but wasn't tuned for gears or converter. Not ever right.
Issues I have: Stalling going in reverse, coming off the throttle the RPMs surge, and intermittently stalls out. I've done some work to the idle now that I have HP tuners.
idles a lot better haven't had and issues in reverse. and rpm surge is a lot better. now when I'm coming off the throttle, after being at higher speed for a n amount of time (interstate driving) it'll stall out when I fully let off the accelerator. Not all the time but enough to be an issue. Also been plagued with Converter flashing, IE when doing a hard acell speedo stays pegged at 0 until I let of the gas for a moment then snaps up to speed.
I haven't attempted to tune shift point or any thing much past idle, and followed CoolAid's guide for the 4L65E tranny, Tuned out TC lock in 1-3, WOT, and raised the Engagement point for Lock in 4th.
Haven't touched the timing or Fuel maps yet, as I'm waiting till next pay check to get a Wideband. Would greatly appreciate some help posting up my current tune, as well as my latest scan file. Not sure why but this last scan the MPS weren't registering in the Scanner. Speedo in dash worked just not on the HP tuner scanner.
20140824 - Idle - Decent, Shfts - Good, Stall x1.hpl
20140824 - GearChange + TC Tunning, Idle Attempt.hpt
