Results 1 to 19 of 19
Thread: 2011 Shelby GT500 ETC Boost limiter?
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    I've run into a brick wall with a limiter on a 2011 GT500.. Seems that no matter what table I increase for commanded torque or do a complete disable of all torque calculations, the ETC still closes. Although not as rapidly with the complete torque disable, but still going down to 70% at redline.
    There is a good 40-50whp still to be made if this can be deleted. The 2011 doesn't have the same tables as the 2012/2013 Shelbys.
    Maybe something to look into? Or is there something I'm missing?
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Oct 2007
    Crawfordville, FL
    2,422
    Quote Originally Posted by Trailblazin' View Post
    Does it happen on the street, or only on the dyno?
    Eric Brooks
    HP Tuners, LLC
    Mar 2006
    Kuwait
    1,564
    only managed to tune it on the dyno.. never datalogged it on the streets..
    my dyno is a loaded dyno, so should be the same as the street..
    Bader Norris
    MEP Tuned
    Instagram
    Oct 2007
    Crawfordville, FL
    2,422
    See if it happens on the street. Front tires aren't spinning on the dyno
    Mar 2006
    Kuwait
    1,564
    still have a closing etc even on the road.. disabled all torque management to the extent the throttle lags after a WOT run..
    Bader Norris
    MEP Tuned
    Instagram
    Oct 2007
    Crawfordville, FL
    2,422
    Stock or aftermarket TB?
    Eric Brooks
    HP Tuners, LLC
    Nov 2009
    All Around
    3,149
    post file, did you modify DRIVER DEMAND what is your pedal START & END set to?
    Mar 2006
    Kuwait
    1,564
    eric, seems to be a load limiter..
    Im reading airload maxing and staying stable at 1.57.. Etc goes down to 75% then to 45%... Like how u explained in the 2013/2014 GT500 stuff, no matter what power is always in 10hp of each other.
    All limiters I've maxed out to 2.0 and I've disabled all torque tabs and tables.
    Can you look into it please?
    Bader Norris
    MEP Tuned
    Instagram
    Mar 2006
    Kuwait
    1,564
    Eric, any updates?
    Bader Norris
    MEP Tuned
    Instagram
    Oct 2007
    Crawfordville, FL
    2,422
    Email support and I will look into it.
    Eric Brooks
    HP Tuners, LLC
    Mar 2006
    Kuwait
    1,564
    sent! thanks
    Bader Norris
    MEP Tuned
    Instagram
    Sep 2014
    3
    hey
    How did u solve the issue !!! i have the same thing with shelby 2011
    1. speed limit is never changing
    2. no matter what adjustments i do for the AFR it stays the same!!
    thanks
    Nov 2009
    All Around
    3,149
    whats your AFR, any parts
    Mar 2006
    Kuwait
    1,564
    Seems I've hit another limiter. The customer has added a crank pulley and we're getting around 19lbs of boost out of the blower. End of the run the throttle body is closing down to 91% then to 85%.
    With just the upper I had increased the load limiters as Eric suggested, but now all limiters have been maxed out.
    Would Pedal POS WOT end have anything to do with this?
    Bader Norris
    MEP Tuned
    Instagram
    Mar 2006
    Kuwait
    1,564
    Looking over the file, ETC Torque management seems to come into play.
    There are 2 tabs:
    - Scheduled Torque Max (Set to stock values - I will increase and try this out)
    - Torque Max (Which I had previously maxed out.)
    If anyone else has any other ideas, please put some input in. With regard to the 2013/2014 GT500s, there seems to be a limiter which is: Load Limit vs RPM vs ECT.
    http://www.hptuners.com/forum/showth...ighlight=GT500
    I normally see loads of 1.85 but once I hit that, load decreases an the throttle seems to close?
    Is this something HP Tuners needs to add for the 2010/2011 GT500s? Or would it be something completely different?
    Bader Norris
    MEP Tuned
    Instagram
    Nov 2009
    All Around
    3,149
    what do you have your start and end WOT?
    Mar 2006
    Kuwait
    1,564
    Factory settings
    Bader Norris
    MEP Tuned
    Instagram
    Oct 2007
    Crawfordville, FL
    2,422
    Are the torque and torque inverse tables accurate?
    Eric Brooks
    HP Tuners, LLC
    Isnt it driver demand table limiting it?
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
