Originally Posted by
jimmyblue
Add "TCC Mode" to your next scan session and look at
what it says in the table view when you think it should
be locked, but isn't. Table view, because you can't plot
or histo it on account of it's displayed as non-numeric
data (why? hint, hint, dev team).
If you see "--3--" then misfire detects are inhibiting lockup.
Look at the various Misfire Current Cylinder PIDs for any
that seem to stand out "above the noise", for something
that deserves attention - if they all just rattle around,
onesy-threesy and sometimes go to zero on the cylinder,
that's normal-ish and nothing to do but live with it. But
if you have one that's a flagpole then chase it - you do
not want, say, the semi-silted #8 injector to give you a
holed piston when you put the blower on.
This is pretty common with lightweight converter or cam,
you have both. Try doubling the values in the various
misfire xxx mode tables if you want to keep some basic
detection capability, or just jam them all to 32767 and
forget misfires.
