my.cfg
hello gurus.
im trying to get standalone working cos' my laptop doesnt live very long under battery and ive read its bad to use an inverter... but so far ive had no luck.
so i have:
set up all the PID's in the "tables"
double checked that all sensors are supported and working
got my wideband working perfectly
noticed i had lots of "parameter not supported" on the histograms, so anything that wasnt supported i just loaded a default "timing PID" 6 times that i know is supported
saved "my.cfg"
turn ignition to "run"
connected the scanner
clicked "scan>mvpi datalogging"
clicked "write config"
waited till finished then closed the window
now in the help vid it says to disconnect the scanner, but mine seems to self-disconnect as soon as write config is finished... it that normal?
so then unplug USB
start engine
press "record" ~2 seconds
all 3 lights light up briefly, then "BUSY" light shuts off and the red ERR light stays lit until i plug the scanner back in. it even stays lit after ive killed the engine.
please help. what am i doing wrong?
*its good to not that i have repeated the above steps about 5 times now. each time has behaved exactly the same, no change.
